Printing from Vista
ferret1979
I print to a wireless printer using a local port IP Address on the computer.
It works fine on XP, I think it may be a driver issue, (the printer is HP Deskjet 3650) and the only driver I can find is the one built into Windows Vista.
I have visited the HP website, and there doesn't appear to be a driver for Vista, and tells you to use the one from Windows.
It prints out some of the page, but not all of it.
If someone could offer some advice I would be grateful
Ferret1979
leeboy1411
Hi there
Vista should have some deskjet drivers already installed, i would try these and is a case of trial and error, HP are not creating drivers for hardware over 7 years old, if the built in drivers in vista don't work then you may find yourself forking out for a new printer
