Printer help please
Discussion in 'Computer Peripherals & Consumables' started by JSW, Dec 9, 2003.
  1. JSW
    JSW
    Feb 21, 2002
    4,229
    Staffs
    +313
    I have a HP deskjet 970cxi and using hp cartridges is great but they cost a fortune!!!
    So I got some pcworld own brand ones and now only have problems :(
    I got 2 pcworld coour carts and one of them only prints black and yellow, no cyan or magent
    the other only prints black and cyan no magenta or yellow!!!
    I read somewhere its the chip in the cart and there is a way to get them working properly but cant remember where i saw it?
    Anyone here able to help ??
    Failing that I may take the carts back and shove um up customer services botts and get a new printer instead.
    Bry
  2. Kramer
    Kramer
    Tried a head cleaning cycle?
  3. JSW
    JSW
    Feb 21, 2002
    4,229
    Staffs
    +313
    Hi Kramer,
    Yes tried head cleaning, printer head allignement several times over.
    Its got something to do with the electronics on the carts.
  4. Kramer
    Kramer
    Hi Bri.
    Someone posted a link to a little add that reset them buggers a while ago (Lynx I think).
    Didn't work on my Epson but you might be lucky.
    Worth a search anyway.
  5. Kramer
    Kramer
    Only works on Epsons (not mine though :().
    http://www.ssclg.com/epsone.shtml
    Might be some help there though, forum etc...
    :smoke:
    I could swear I saw something like this with HP support.......
  6. JSW
    JSW
    Feb 21, 2002
    4,229
    Staffs
    +313
    Cheers m8ty will go take a look :)
  7. JSW
    JSW
    Feb 21, 2002
    4,229
    Staffs
    +313
    Took the carts back to pc world this morning.
    The guy pointed to the electronic contacts and said theyre the problem, go and get 2 HP ones if you want.
    I asked if I could have the value of a new printer instead, no problem he said :)
    So got THIS
    with £50 off ;)
    Not bad considering I bought the carts months ago, had no receipt and bought them with a buy any 2 carts for £10 each voucher ;) heehhehehe
