Printer advice
Discussion in 'Photography Forums' started by bobbles, Aug 6, 2003.
  1. bobbles
    bobbles
    Just got an A70 any advice / recommendations on a printer would be gratefully received.
    Ideally i would like a decent printer (nothing flash cheap as possible) which is cheap to run. I currently have a Epson C60 which uses up ink very quickly.
    Also where are the best places to get the photo quality paper
  2. Hugo Junkers
    Hugo Junkers
  3. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    Canon i850 is worth a look at about £150.
  4. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    There are many reviews on the web of printers.
    Have a look at recent ones at www.computershopper.co.uk and www.photo-i.co.uk
    Do you want a photo printer (six ink) or just good colour? A4, A4+ or large format?
    Both Canon and Epson have good reports on their 9 series models, and best results are on their own branded paper.
    One thing to consider is that Canon uses dye inks which may fade relatively quickly (months in some cases), and Epson uses pigment inks which last considerably longer (years) with the right paper.
    I have also read posts on other forums of a "major announcement" to be made in the middle of August by a leading printer manufacturer. Rumours are of a new model, new technology or improved printing method. So it may be worth waiting a while.
    woody
    [edit: inks are now associated with the correct manufacturer. Doh!]
  5. GrahamC
    GrahamC
    Jul 22, 2001
    2,258
    Morecambe, U.K.
    +67
    Is the description of the inks used the other way round.:confused:
    H.P. is about to announce a major event I understand.
  6. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    No ..... the description is correct but the manufacturers are the wrong way round:blush:
    Yes, Epson = pigment and Canon = dye
    Dye fades quicker
    woody
  7. bobbles
    bobbles
    great link hugo cheers
    I will defo go the boots root as my normal printer is ok for the amount I use it at home (usually print stuff out at work)
    I didn't even realise photo developers developed from the flash cards
    top stuff
