Primare Dvd / Infocus 5700
Discussion in 'Projectors, Screens & Video Processors' started by preciousskiing, Jan 5, 2005.
  1. preciousskiing
    preciousskiing
    :lease: My first projection experience!!! Have just purchased a Primare 26 DVD player and Infocus 5700 projector. PROBLEM:- when using progressive scan output from player I get horzontal black breakup lines only along the bottom six inches of the projected picture when there is movement. On interlaced output there is no problem. Next problem!!! I switched Primare infra red detector to rear from set up menu and now remote won't work as there is no rear detector on player. I can not therefore get back into set up menu to change this back as the remote won't work!!!! What do I do now???? PLEASE CAN ANYONE HELP ME ??? Thank you ... Bob
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    May be worth trying to sort out the DVD menu issues on the DVD player forum, then come back to this forum for the PJ stuff...
    Good luck!...PJ
