For Sale PRICE DROP: Speaker Cable - AudioQuest Type 4
Discussion in 'Archived Classifieds' started by df1603, Dec 22, 2017.
  1. df1603
    df1603
    Aug 14, 2002
    345
    +13
    Pair of the legendary AudioQuest Type 4 speaker cable. Star geometry with 4 solid copper conductors per cable. The length is 4.6m each between termination points. The cables are terminated with spades on the speaker side. On the amp side there are Nakamichi Banana plugs. Due to 4 wire star construction these cables can be terminated in bi-wire option on the speaker side if you wish to do so.
    The 4-Series of AudioQuest speakers cables may be the most successful in AudioQuest’s 30+ year history. Type 4′s roots go all the way back to the late 80′s. The fundamental geometry and conductor complement of Type 4 hasn’t changed since 1995 … because any change to the size or position of the 4-Series’ 2-sized Spread-Spectrum conductor arrangement would reduce performance.
    SOLID LONG-GRAIN COPPER (LGC) CONDUCTORS: Type 4’s solid Long-Grain Copper allows a smoother and clearer sound than cables using typical OFHC (Oxygen-Free High-Conductivity) copper. OFHC is a general metal industry specification regarding “loss” without any concern for distortion. LGC has fewer oxides within the conducting material, less impurities, less grain boundaries, and definitively better performance. All four of Type 4’s conductors are solid. Electrical and magnetic interaction between strands in a conventional cable is the single greatest source of distortion, often causing a somewhat harsh, dirty and confused sound. Solid conductors are the most important ingredients enabling Type 4’s very clear sound. Whether a conductor is solid or stranded, skin-effect is a prime distortion mechanism in speaker cables. Type 4 very simply keeps this effect out of the audio range by using conductor sizes that are below the threshold for audible distortion.
    CARBON-BASED NOISE-DISSIPATION and CROSS-TALK-DISSIPATION SYSTEMS (INSULATION): The two negative conductors in Type 4 are insulated with partially conductive Carbon-Loaded Polyethylene. This remarkable material damps radio-frequency garbage from being fed back into the amplifier. The sonic benefit is exactly the same reduction in “hash” and better dimensionality that comes whenever RF garbage is reduced in an audio circuit. Type 4 uses Nitrogen-Injected Foamed-Polyethylene Insulation on its positive conductors because air absorbs next to no energy, and Polyethylene is low-loss and has a benign distortion profile. Thanks to all the air in Foamed-PE, it causes much less of the out-of-focus effect common to other materials.
    STAR-QUAD GEOMETRY: The relationship between conductors defines a cable’s most basic electrical values (capacitance and inductance). However, even when those variables are kept in a reasonable balance, the relationship between conductors can be varied in ways that greatly affect the sound. The Star-Quad construction of Type 4 allows for significantly better dynamic contrast and information intelligibility than if the same conductors were run in parallel.
    SPREAD-SPECTRUM TECHNOLOGY (SST): Any single size or shape of conductor has a specific distortion profile. Even though radially symmetrical conductors (solid or tubular) have the fewest discontinuities, any conductor of a particular size does have a sonic signature. SST is a method for significantly reducing the awareness of these character flaws by using a precise combination of different size conductors. The different SST-determined conductor sizes used in Type 4 allow an exceptionally clear, clean and dynamic sound.
    Price and currency: £149 £99
    Delivery: Delivery cost is included within my country
    Payment method: PPG/BT
    Advertised elsewhere?: Not advertised elsewhere
    Prefer goods collected?: I have no preference
    ______________________________________________________
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via private conversation to each other after negotiations are complete and prior to dispatching goods and making payment:
    • Landline telephone number. Make a call to check out the area code and number are correct, too
    • Name and address including postcode
    • Valid e-mail address
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
  2. df1603
    df1603
    Aug 14, 2002
    345
    +13
  3. df1603
    df1603
    Aug 14, 2002
    345
    +13
    this solid cable will make your speakers sing :smashin:
  4. df1603
    df1603
    Aug 14, 2002
    345
    +13
