previous post - yamaha without sub - sub added but set up problems - URGENT HELP ??
Discussion in 'AV Receivers & Amplifiers' started by samjet, Feb 4, 2005.
Tags:
  1. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    following on from my post this am have added the sub and gone though the set up proceedure and all is seemingly ok
    BUT the on screen menu will not work
    after its gone through the set up i'm left with a screen on the amp which says
    FRONT L .......OK
    when i press select i go the the menu and choose SET - press SELECT and it reverts to auto set up!!!!!!!!!!
    have tried the proceedure about 10 times and result is the same - i cannot set my settings and exit the screen
    is it me or the amp????
    please help
    if any kind soul wants to talk me through it pm me your phone number and i can ring you
    thanks
  2. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    Sorry Samjet, I missed this earlier. you're hitting the wrong button. Use the arrow cursor keys to scan through the settings, not the select button. (I think that's right, I'm not in front of the amp). the manual is pretty good for walking you through the basics, I did my first pass with it on my knee while I hit various bumps in the road.
    Failing that, come out of the setup menu and use the level key and scan though the speaker setting with that - the cursor keys let you change db levels and sub crossover etc.
