Preview edited work on television
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Gromit, Mar 15, 2005.
  1. Gromit
    Gromit
    Nov 30, 2004
    524
    Copenhagen
    +42
    I have Vegas 5 and would like to preview my edited work on my televison for reference purpose.
    How would I go about doing this cheaply? I only have an old 32MB Geforce 2 MX graphic card. Would a TV in/out tuner card do?
    The best option would be to buy a Canopus ADVC-110 Digital Video Converter, which is the best one to get. However, this one is fairly expensive.
    Would also love to have two CRT monitoirs when editing, but this requires a dual-head graphic card.
    I would sincerely appreciate any help in this matter.
    Regards,
    Gromit
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    If you want to do it from the timeline you will have to use the firwire out to a digital analogue converter (like the Canopus) or pass through on your camcorder if it does it, then into your monitor.
    The 110 (formerly 100) & above are bi-directional , the 50 is only analogue to digital.
  3. Gromit
    Gromit
    Nov 30, 2004
    524
    Copenhagen
    +42
    So if I was to buy the Canopus ADVC-110 Digital Video Converter, would it work here if I bought from the US... since it´s cheaper over there?
    What mean is it 110 - 240 V compatible?
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    It's 100-240v & the UK version comes supplied with an appropraite AC adaptor.
    The manual will state only the supplied adaptor should be used & then there is warranty considerations if purchasing from USA
  5. Gromit
    Gromit
    Nov 30, 2004
    524
    Copenhagen
    +42
    Thanks, for the info.
    Anyway, I own a several US step up/down voltage converter. I guess, I´ll be safe in case I buy one from the US.
