preventing screen burn on toshiba 46who8b tv
Discussion in 'General TV Discussions Forum' started by charles, Sep 2, 2001.
  1. charles
    charles
    Jul 6, 2001
    1,367
    63
    norwich
    +179
    I AM VERY CONCERNED REGARDING SCREEN BURN WITH THE ABOVE TV.THE MANUFACTURERS HANDBOOK IS VERY VAGUE.CALLING THE TOSHIBA HELPLINE HAS NOT BEEN VERY CONSTRUCTIVE.THE SIMPLE QUESTIONS I WOULD LIKE ANSWERED ARE THESE.<br />1.WHAT LEVELS ARE THE MAXIMUM THAT THE BRIGHTNESS,CONTRAST AND SHARPNESS CAN BE SAFELY SET TO.<br />2.AS ALL SATELLITE CHANNELS CARRY SCREEN LOGOS,WHICH ONES ARE PERFECTLY SAFE TO VIEW AND WHICH SHOULD BE AVOIDED<br />HAS ANYONE HAD A DEFINITE ANSWER FROM TOSHIBA OR ANY OTHER MANUFACTURER REGARDING THIS PROBLEM
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Set the contrast and brightness in the 45-50 range and you shouldn't have too many problems.
    If you must watch 4:3 material as 4:3 then i make sure that i switch between the formats in the adverts of every 1/2 hour or so, else use "superlive". <br />With regard to screen logos, most that appear "washed out" should be fine, again if it is a solid logo i switch between the picture formats periodically to move the logo about.
    Happy watching, the tosh wh08 set are great. <img src="wink.gif" border="0">
