Pressence Speakers, Di/Bi poles or Normal?
Discussion in 'Home Cinema Speakers' started by pragmatic, Dec 29, 2004.
  1. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Which would be better for the pressence speakers? They are ment to be used for dialogue so i'm guessing normal speaker would be better, any ideas?
  2. recruit
    recruit
    Normal speakers would be more suited as dipoles and bipoles are for surround duties.
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    How about using another two centre speakers, or would this be wrong/overkill?
  4. recruit
    recruit
    I would think that 2 larger centre speakers would definitly be overkill as the presence speakers run at alot lower output to the rest of the speakers.
    Do you have a Z9 or another model in the Yamaha range as my presence speakers power output is only rated at 50w compared to 170w for the rest of them and if i was going to run them i would not put anything too power hungry on them.
    John
  5. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    Yea, i was thinking of the mission m30's/m30i as they look good and seem to pretty decent speakers. Also as it's mainly dialogue it's handling theres no need for bass, main/sub handles that anyway.
    A few models down from the Z9 as i can't aford that (yet!)
  6. recruit
    recruit
    They look ideal :thumbsup: just had a search and look perfect for the job!
    John
