Presets on the Panny ae100
Discussion in 'Projectors, Screens & Video Processors' started by Donnacha, Aug 1, 2002.
  1. Donnacha
    Donnacha
    Jul 4, 2002
    8,258
    York
    +4,392
    just a thought re: the Panny ae100 - is it possible to have user presets to store your favourite configurations for different inputs -for example on certain letterboxed films the subtitles are below the image in the black bar area. On my TV I can move the image up so I can see the subs and still retaining the full image. Can I do this on the Panny and be able to recall it at the touch of a button, or like my TV do I have to set it up everytime?
    I haven't got one yet but I'm getting there!!
    Thanks to all in advance
  2. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Dont see it on mine.............there is a function to move the pic around though
  3. Donnacha
    Donnacha
    Jul 4, 2002
    8,258
    York
    +4,392
    Thx Walter Mitty,
    I've had a look at the .pdf manual on the panasonic site - it doesn't look like you can save it as a preset. Well at least you can move it around, which will still achieve the desired effect.
