Preset Codes for Denon DHT-500
Discussion in 'Home Cinema Buying & Building' started by bewilson, Jan 21, 2005.
  1. bewilson
    bewilson
    In the manual there is a list of 3 digit preset codes for different brands. I use to have my DHT-500 hooked up to a Sony TV but have recently brought a Dell 17" Flat screen monitor/TV that I have set it up with. There is however no entry in the list for Dell products. I have tried putting in a number of different codes from other brands but no luck. Does anyone know if Dell products have such a code? I have contacted Dell support but whoever logged my case didn't seem to know.
  2. bewilson
    bewilson
    Sorry, these codes enable you to use basic TV functions (on/off/change channel/volume etc) on the Denon Remote Control unit instead of having to use the TV remote control.
  3. Conn
    Conn
    Jan 2, 2005
    2,074
    +170
    I think it may be more use calling Denon rather than Dell.
  4. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    While you're trying codes, try the Acer, Relisys and Hitachi ones...just an idea.
    Jimmy
