Preset codes for denon 3801
Discussion in 'Home Cinema Control & Remote Controls' started by jasonb, Mar 18, 2003.
  1. jasonb
    jasonb
    Hi there does anyone know where I can fin the preset codes for the learning remote which comes with the denon 3801:)
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,675
    UK
    +115
  3. jasonb
    jasonb
    Just went onto the web site went into search Denon 3801 but nothing came up any ideas where to look on the site. Thanks for the help guys:zonked:
  4. Flimber
    Flimber
    Sep 22, 2002
    13,507
    Yorkshire
    +4,460
    Manual is available online, are they in the back of that ?
    Mike.
  5. jasonb
    jasonb
    afraid not.... have the manual here. The dog went medevil on the remote for my LG DVD player, so I can't watch any movies (except warner bros as they start automatically) and I'm getting sick of the lethal weapon movies even though they are good, if you know what I mean. I will get a pronto in the next couple of months but until then I shall have to make do with the denon remote. ;)
  6. Flimber
    Flimber
    Sep 22, 2002
    13,507
    Yorkshire
    +4,460
    Ring/email Denon (or their distie here).
    Mike.
  7. jasonb
    jasonb
    Good call I'll go to there web site and e-mail them....Sometimes the simple things stare you in the face. Doh!
    Jasonb
  8. Flimber
    Flimber
    Sep 22, 2002
    13,507
    Yorkshire
    +4,460
    List of codes in the middle of the AVR-1803 manual online (different remote but may be the same learning bits).
    Mike.
  9. jasonb
    jasonb
    Cheers mate I'll have a look at that and the on line manual for 3801 to see if it is different to the maual I've got.
  10. jasonb
    jasonb
    Hi there
    where did you find it online I only found one site and it wasn't working. Cheers
  11. Flimber
    Flimber
    Sep 22, 2002
    13,507
    Yorkshire
    +4,460
