preparing to hook my HC kit up?
Discussion in 'Home Cinema Speakers' started by Help, Aug 16, 2003.
  1. Help
    I have recently bought the Velodyne VX-10 sub and a Tosh SD300 dvd player. I am picking up Five Mark 2 KEF eggs next week and also a Denon 1803 amp. My question is what cables will I need to hook it all up?
    I have a Scorpion digital coaxial cable and sub cable on order, and I know I'll need speaker wire. Is there anything else that I will need?
    thanks in advance
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    With the equipment you have listed, the cables on order (plus speaker cable) you will have just about all you need (except power cables :clown: ).
    If you want to play CD's on your DVD you might want to get a sterio pair of phono leads, or you could just stick with the digital lead. The choice is yours.
    If you have a nicam VCR &/or TV then you might also want a sterio pair of phonos to go from one or both of them to get the sound out your speakers in Dolby Pro Logic I/II.
    Other than that its just getting cables as and when you plug any other equipment in.
    Mark.
  3. Help
    Cheers that's a relief. I'm not too bothered about music or the video, so looks like I am set.
