Preouts and High level saturations ?
Discussion in 'AV Receivers & Amplifiers' started by Milenario01, Jan 7, 2003.
  1. Milenario01
    Milenario01
    DEar colleagues:
    Is there any problem in connecting an A/V front speakers preouts to line levels of an stereo amp? I see it is a typical configuration for a lot of people to get the best of Home Cinema and Stereo worlds, but ...
    Line level inputs voltage: 140 mV
    Pre-out outputs: 3-4 volt .
    Any saturation problem could occur with this ???
    Thanks !
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    That's a big difference, the docs for my preamp state :-
    Preamp Output Level - 1.2 V (200 mV Input)
    Which implies an output of 1.2V is suitable for a 200mV Input on the power amp, so it would seem it's fine but I don't know how, any techies explain this ?
