Premier Pro and Pinnacle moviebox question
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by robroy, Nov 28, 2004.
  1. robroy
    robroy
    I use Pinnacle Studio 9 (with a break-out box)to capture footage and Premier Pro to edit the stuff, but for some reason Premier won't capture footage directly using the break-out box, although it's quite happy to capture DV footage through the firewire port. It doesn't even recognise the pinnacle box as being available, any ideas?
  2. robroy
    robroy
    Premier Pro is now really getting on my wick!
    Can anyone explain why I import a clip into Premier pro, it plays okay on the monitor (source) but as soon as I move the clip onto the timeline... No sound!?!?!
    Anyone?
  3. MikeNelson
    MikeNelson
    Jan 11, 2003
    130
    Isle of Wight
    +3
    Does the Pinnacle use a proprietary avi format - my ancient DC30+ certainly does and the sound goes back through the capture card rather than through the PC hardware. Try connecting the monitor to the outs of the breakout box. This may also explain the other problem
