Prem Plus + upgrade sub
mose72
Hi all
I have the ms premier plus with the 308 sub, i am looking either to upgrade the sub or get some cantons also with a new sub (cd 50 x 2, cd 360 x 1, cd 10 x 2).
Either way could you offer either pointers for a new sub for the 308 or one for the canton set up?
Many thanks
BRVF
Ed Selley
AVF Reviewer
For upgrading the existing speakers, the 309 is just the ticket but I would (under duress) suggest that if you have a view to changing to bigger speaker (irrespective of brand) a BK or other large speaker companion sub might be worth a look as well.
mose72
For example?
Ed Selley
AVF Reviewer
The 309 was designed to be an upgrade for the premiere system and a sub for the 902/4 sized speakers. Our large speaker sub is the 909 which is designed to offer greater low end weight. My point is that if you change to full size front speakers, the 309 is not going to add as much meaningful low end as subs like the BK which (whatever eviljohn says :)) is designed to work with full size speakers rather than sats (although it isn't shabby with them either).
mose72
Right ho, would you consider the Canton set up mentioned above a large speaker set up?
