Prelim Checks on SD210E - no thanks or go for it anyway????
Discussion in 'Blu-ray & DVD Players & Recorders' started by samhassall, May 11, 2001.
  1. samhassall
    samhassall
    Not sure if I want an SD210 now if I need to do prelim checks on RCE discs. Should I go for something else instead? Panny RV20, Sharp DV700 or Sony 336 for example?
    Techtronics say that the 210 "may" need prelim checks. Does this mean that I will have to do an R1 swap everytime?
    I have heard that the JVC 521 plays RCE discs without a problem, when Techtronics say this players needs prelim checks.
    I am really confused now.
    Somebody help! :rolleyes: :rolleyes:
  2. GarethH
    GarethH
    Aug 31, 2000
    325
    UK
    I spoke to Techtronics yesterday. Due to complications, the new Toshiba 210E will only be Auto Switching, but they have enabled it to play RCE when you insert a normal disc in first.
    IMO - Do not buy the machine. My current Pioneer 626D has to do this method and its really annoying everytime you wanna sit down and watcha film. I was planning to buy the Toshiba 510E in August, but since it might have this RCE swap thing, i aint gonna bother. Maybe they'll have a even newer mod then.
    I can tell you now that all new Warner and Columbia/Tristar will be RCE. Bah, i hate these companies.
