preamp+amp=?
Discussion in 'AV Receivers & Amplifiers' started by yiannisvog, Dec 27, 2001.
  1. yiannisvog
    yiannisvog
    Hello everybody! I have a DENON AVR 3801 as the preamplifier and an ADCOM GFA 7500 (5 channel) as my amplifier. The ADCOM gives 150W/channel. Does the preamplifier increases the final power/channel.
    Thank you and i wish you all have a very happy new year!
  2. salizar
    salizar
    Yiannisvog,
    Amplification is provided by the power amplifier while the preamplifer processes the signal - so the answer to your question is; no it does not increase the final power/channel.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,498
    Rainham Essex
    +2,507
    In very, very, very simplified terms the preamp turns the power down, not up.
    If you connect the 5 channel analogue outputs from a DVD player directly into a 150w per channel amp then all 5 channels would play at 150w all the time.
    Plug in a preamp and you can turn the volume of each channel down to a reasonable volume.
    Mark.
