bellissimo
Established Member
I am considering buying the Sony RDR-HX510. I would be mainly using it to archive programmes from my PVR box onto the HDD, edit, then burn to DVD-R. However a couple of issues are not clear to me.
1) I have seen it stated that manually added chapter points (or their thumbnails?) do not get included in the final DVD. However if you choose to add chapters at defined intervals they do get included. Is this true?
2) I would like to daisy chain my Freeview with the Sony, with the Sony acting as a pass-through for RGB. However, for DVD playback, I would like to use the component video connections. Is this possible without any fiddling, or would I have to toggle a setting on the Sony every time I wanted to watch a DVD?
3) The majority of things I would archive would probably be films recorded from the PVR. Is it true that if a film is over 2 hours 30 minutes, the resolution on the DVD would be halved?
