Pre-programed remote codes for Sky Digibox?
Discussion in 'Home Cinema Control & Remote Controls' started by RobbieD, Nov 18, 2003.
  1. RobbieD
    RobbieD
    Jun 7, 2001
    115
    London
    +10
    I already posted this question under Amplifiers and Receivers, but maybe I should of asked here as it is a pre-programed remote question.
    The Pioneer VSX-C100 AV amp comes with a preprogramed remote. Using the codes in the manual I have been able to get it to control my Sony DVD, Grundig VCR & Mitsubishi TV. Pioneer also give codes for Satelite & Cable boxes from Jerrold, SA, Zenith & Pioneer. (I guess these are all US boxes.)
    But no codes are given for Sky Digital Boxes. (I have tried these all and none work.)
    Does anyone know it this remote can control the Sky box? (Even only channel up/down would be better than nothing.) Do you know the 3 digit code needed.
    I suspect that the remote may use a standard preprogramed chip used in many other remotes, and most seem to include Sky codes.
    The Pioneer part number on the remote is AXD 7323.
