Pre/pro for Rotel RMB1095
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Snippermanden, Dec 2, 2003.
  1. Snippermanden
    Snippermanden
    Aug 26, 2002
    23
    decisions decisions.....
    I have set my mind on a Rotel RMB1095 which was a fairly easy pick, hugely oversized for my current speaker setup but I do not want to upgrade ever again (wishful thinking).
    Now the tricky part is to choose a pre amp / processor for to feed the thing. I do not think that the Rotel RSP 1098 is a realistic choice - it is VERY expensive (3.500 Euros).
    My local hardware pushers logical alternative is the RSP 1066, which I quite honestly also find a bit pricey. I really like the new receivers from Yamaha and Pionner with their automatic speaker setup features. Now I know that the amp section of those boxes are quite inadequate, but how would they perform as pre/pro's for my Rotel amp? Particulary compared to the Rotel RSP 1066, do they offer decent bass management, and how does the processing and 2 channel sound compare?
    Hope you can direct me and please do not refer me to the "Rotel Forum". They seem to be a bit biased towards Rotel ;-)
  2. rags
    rags
    Apr 13, 2003
    4,086
    London
    +301
    Now that you have decided to go for a 1095 I wouldnt bother getting an integrated amp as you are paying for something you dont need plus a dedicated processor will sound better.
    Up untill a few days ago I used to own a 1095 and used it with a TAG processor. A very good combination. Used TAG's can be had for about 1500 pounds or less so they represent good value. I personally would not bother with the Rotel 1066 - for a few pounds more you can pick up a used processor and it will be well worth the extra - Lexicon MC1/DC2, TAG, Meridian 568 all spring to mind and represent very good value in the second hand market - see the forum classified ads section.
    By the way the 1095 is an absolute belter of a power amp. Good choice.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    The RSP1066 is a very good pre/pro and good value for money. Depending on what you are trying to do it could be a better choice than a 2nd hand Tag or Lexicon, especially if you are using a sub/sat system.
  4. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Can you elaborate - I don't understand.
    I'd also say that moving from one of the older Rotel processors (the RSP966) to a Tag AV32R was night and day - massive difference in favour of the Tag. I'm sure the Rotel 1066 is a fair bit better than the 966 but up to Tag/Lexicon standards?
    Matt.
  5. Spligsey
    Spligsey
    Jan 16, 2003
    2,069
    UK
    +137
    Meridian make the best dual purpose machines.
    Dual purpose as in Movies & Music
    Adz
  6. lovegroova
    lovegroova
    Jul 15, 2002
    2,536
    103
    Herts
    +297
    I use a TAG AV32R with my 1095. It is great for movies using the digtal inputs, and for music using the bypass. Look at www.ex-dem.co.uk for bargains, as well as the usual places for 2nd hand.
  7. rags
    rags
    Apr 13, 2003
    4,086
    London
    +301
    Yup a very good combination. The guy who bought my Tag and Rotel 1095 had a listen before we packed it up - he thought I was completely insane selling it and to be honest I still am not completely sure I made the right decision. Hopefully when my new kit arrives all doubts will go away.
    Jeff - what do you mean - why would a Rotel 1066 be a better choice than a second had TAG or Lexicon when using a sub / sat system. I have listened to a 1066 in action and although it is a nice piece of kit, frankly it doesnt even compete with a TAG AV30R let alone the more expensive TAG models. And that was using a sub/sat system (M&K 850 series)
  8. Snippermanden
    Snippermanden
    Aug 26, 2002
    23
    Now Im the (unfortunate) resident of a very small highly taxed country which means that a TAG processor is not available as 2. hand. You all know what that means!
    From what I have heard the 1066 is very nice, but is is much nicer than the pre/pro part of a Yamaha RXV-1400 Receiver? Particulary if you consider that the Yamaha is much cheaper.
  9. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    If it's any consolation the RSP-1098 costs the equivalent of USD4000 here in Taiwan. And it's 110V only. :(
  10. kocl
    kocl
    Jan 8, 2003
    589
    PORTUGAL
    +13
    The question is does the 1098 worth the price?
    what is the gain.
  11. Audionyx
    Audionyx
    Dec 10, 2002
    667
    East Yorkie Porky
    +20
    I have recently sold my stereo equipment to consolidate my electronics somewhat! I went for the RSP-1098 and 1075 combination.
    I have been delighted with my purchase and have been very impressed by the performance of the Rotel gear whatever the mode of operation (stereo or AV).
    The 1098 uses the very latest DSP from Crystal Semiconductor (a gerneration ahead of some pricier UK models) coupled with advanced DAC's. It used a modular design internally and is firmware upgradeable.
    Basically it is designed in the UK/Japan and built in China therefore giving fantastic design and performance while taking advantage of lower manufacturing costs.
    I have been blown away by this combination and it some of the UK built competition ;) that I have heard.
    Regards
    Darren
  12. Audionyx
    Audionyx
    Dec 10, 2002
    667
    East Yorkie Porky
    +20
    oops - typing too fast while not using brain!
    Should read "I have been blown away by this combination and it performs better than some of the UK built competition"
    Tut-tut-tut!
  13. kocl
    kocl
    Jan 8, 2003
    589
    PORTUGAL
    +13
    Hi, i love stereo as much as av, and its good to ear that 1098 performs stereo very good.
    Is the power amp 1075 enought or should buy the 1095.
  14. Audionyx
    Audionyx
    Dec 10, 2002
    667
    East Yorkie Porky
    +20
    Put it this way, the 5 * 120W is enough for me and the load (KEF Q7/9C/Q1). However, the 1095 has twin 1500VA transformers supplying plenty of current for the 5 * 200W output. It really depends on the speakers demands!
    If I had the cash I would have gone for the beefier amp!
    My previous amplifcation for stereo was the Musical Fidelity A3.2 pre/power combination. I never thought I would part with these as for the price they are phenomenal. The Rotel's come close enough in performance for it to be of no major concern - that's a tribute to both products...
    Darren
  15. kocl
    kocl
    Jan 8, 2003
    589
    PORTUGAL
    +13
    My speakers are Kef q55.2 and q15.2 and the central, so i think 1075 is more than enougth.
    My currente av is a yamaha, i hope the differences are abismal.
  16. petrolhead
    petrolhead
    Mar 29, 2002
    4,481
    71
    Newcastle
    +82
    My ten penneth worth
    I use the Tag AV32R with the Rotel 1075 amp and am very pleased with this combination. The Tag is a joy to work with
  17. FazerThou
    FazerThou
    Aug 23, 2003
    1,809
    Bath
    +138
  18. Snippermanden
    Snippermanden
    Aug 26, 2002
    23
    bid risky to buy used equipment abroad!
  19. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Been in Italy so unable to reply.
    There are 2 reasons why I believe why the Rotel could be a better choice. Firstly the Tag and Lexicon don't have nearly enough crossover options, the only realistic one is 80Hz, if you have an anomaly at round the crossover point due to room acoustics you are pretty much stuffed as they say. Sats like Gallos and many others struggle at 80Hz anyway leaving you just the 120Hz option. The Rotel supports 40, 60, 80, 100 an 120Hz crossover points.
    The second reason is that the analogue multi channel input has an analogue 100Hz crossover, this allows you to feed an analogue source such as a CD player, bypass all the processing (A/D, D/A conversion) yet still support the sub/sat setup. The sound is very transparent and IMO better than what the TAG and LEX could achieve with full bass management switched on.
  20. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    Thats all very well, but the Rotels actual quality of the BM is not the match of the Lexicaon or the Tag. In using the (Tag) 5.1 input as connection to a cd player the Rotel is NOTHING like as transparent as the TAG.
    Infact i would take (i.e) a MF 3.2 cd player connected (via sp/dif) to a Tag using the TAGs DAC's - which allows BM or direct modes, over a MF3.2 connected to Rotel 1066's analogue inputs any day of the week.
    The Rotel is not the match of the Lex or Tag in any department IMHO.
    Regards
    Steven
  21. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Steve, have you tried this or is that a wag? Is it that hard to believe that an analogue crossover can beat A/D and D/A conversion with full digital bass management?
  22. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    Jeff.
    Your angle of approach is indeed appreciated, but with reference specifically to the 1066 which i have indeed spent a week or so with, i honstly didn't it was that great as an active pre-amp, just MHO of course. Your points are and would be valid with perhaps something other than the 1066 (just my humble opinion again)
    Does the fact that the 5.1 input having a crossover in it's path not put you off as regards DVD-A/SACD?
    The best option would surely be connect a CD player to the Tag 5.1 bypass which is a true bypass and connect the sub at high level input, this for me would offer transparancy??
    Regards
    Steven
  23. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    DVD-A and SACD aren't a priority, 2ch and multi channel sound from the PC is a much greater priority for me. As they don't have bass management the Rotel offers a neat solution, better IMO than going though A/D D/A conversion and bass management on the older 2nd hand Tag and Lexicon (which is what we are talking about). Using the high level input is an option (if a bit messy) for 2ch but not multi channel. Regarding the lack of crossover options on the TAG and LEX for regular digital stuff, it is my opinion that having a flat frequency response at and around the crossover point is critical for good sub integration. This is one of the reasons is discarded the AV32R and the MC1 during selection. Had either met my requirements I would have been more than happy to go down the 2nd hand route, after all I bought your power amp ;) As it is, I believe I choose wisely as the sub/sat integration between my sats and sub are about as perfect as you can get and from analysis I now know that a 80Hz crossover wouldn't have worked nearly as well.
  24. kocl
    kocl
    Jan 8, 2003
    589
    PORTUGAL
    +13
    is the rotel 1098 good in 2Ch and multi Chanel or there at the same price better options?
