M
Machocomacho
Guys,
I have a denon 3802 which I would like to connect to a
Musical Fidelity F25 pre-amp and F16 poweramp to improve stereo plaback. I was going to use the pre-out ( L / R ) of the 3802 into the AuX input on the pre-amp but I'm not sure if i'm at risk of damaging the pre-amp?
If this will work ok great! if not is there a way I can get this lot hooked together properly ?
Also ... any advice on setting levels once I have it connected together ? I have a SPL.
