Pre-cabling a wall ready for PW6
Discussion in 'Plasma TVs Forum' started by cebs_uk, Sep 29, 2004.
  1. cebs_uk
    cebs_uk
    Jan 25, 2004
    2,537
    Manchester
    +406
    Just wondered if I could get a few views on the correct cable run for the PW6 while my walls are stripped and getting channels dug out.
    I figured on the following :
    1. Power
    2. VGA d-sub
    3. 5X BNC lengths for RGBHV or VUY or composite.
    and then the dvi/hdmi stuff :
    4. Just Dvi cable for the PW6s board.
    or
    4. HDMI cable or the future.
    With either option there are convertors out there that I hope would be compatible for example : on the denon 3910 come out pal/50hz on hdmi then covert to a dvi cable to go into the patch panel.
    Or should I just stick a length of each in and use an adapter at the plasma end if needed ?
    Thanks in advance
    Cebs
