lolgabelol
Hey guys,
I'm looking to upgrade my current rig and was wondering if people could recommend a good pre-built set. I can't build my own PC so I need a site or manufacturer that could do it all.
I want better performance in more simple games like WoW all the way to more demanding features like using my Valve Index for VR. I currently have a 27 inch 4k monitor and can generally get around 60fps for WoW in demanding settings. I'm wondering if it's possible to increase that with a better rig.
My current CPU specs are:
Processor: Intel (R) Core(TM) i7 -6850K CPU @ 3.60GHz
Installed RAM 16.0 GB
GPU: NVIDIA GeForce GTX 1080
Motherboard: ASUSTeK COMPUTER INC.
X99-A II
Rev 1 .xx
Monitors: 27 Inch 4k Asus Predator
LG 27 Inch monitor
LG 24 Inch monitor
My budget is fairly high, probably around 4-5k but I'm wondering if that is necessary given my needs.
Currently I've been looking at 2 distinct builds on newegg.
ABS Legend Gaming PC - Intel i9-10900KF - GeForce RTX 3090 - G.Skill TridentZ RGB 32GB DDR4 3200 MHz - 1TB M.2 NVMe SSD - Newegg.ca
and a cheaper
ABS Gladiator Gaming PC - Intel i9-9900K - GeForce RTX 2080 SUPER - G.SKILL TridentZ RGB 16GB DDR4 - 1TB SSD - Liquid Cooling 240mm - Newegg.ca
My overall goal is to future proof my rig and absolutely thrash games like WoW while also being able to max out my VR games. I think a decent CPU is required for this, that's why I've been focusing on the i9, but in general my knowledge is quite limited.
Thank you! I appreciate all help and tips!
X99-A II
Rev 1 .xx
LG 27 Inch monitor
LG 24 Inch monitor
and a cheaper
