Pre-amp
Discussion in 'AV Receivers & Amplifiers' started by Bassmaster, Aug 10, 2005.
  1. Bassmaster
    Bassmaster
    Hi there... I'm going to get an Audiolab 8000Q pre-amp in september, but just don't know if I can use it on it's own for a while as I will be on a rather tight budget indeed. It's just I've only used intergrated amplifiers up until now, so any information would be grately appreciated. Thanks :).
  2. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Only if you have a power amp or a av amp with 6 channel inputs then you can use the peramp to do all the processing and use the reciever to do all the power amp work.
  3. Astaroth
    Astaroth
    Jun 22, 2004
    2,258
    63
    London
    +101
    Or active speakers
  4. Bassmaster
    Bassmaster
    Thanks. Is it possible to use my exsisting intergrated amplifier as a power amp?, or just the use of an AV reciever as you stated.
  5. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    You can use the integrated amp: connect the pre-outs from the pre-amp to any free line input (e.g. AUX or CD) and the speakers to the integrated amp.
    Set the volume knob of the integrated amp to around 50% and then control the rest from the pre-amp.
    You could also check if the integrated has a switch (usually at the rear) to fix the gain and thus bypass the volume control; some Arcam amps for example have this feature.
