Pre-amp with HT pass through?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Nickyrboy, Jun 14, 2015.
  1. Nickyrboy
    Nickyrboy
    Feb 25, 2005
    71
    11
    Bristol
    Hi all
    I'm looking for a stereo pre-amplifier that has HT pass through direct to the power amp. Lots of integrated amps feature this but not any stereo pre amps. Anyone aware of any?
    To clarify I want a standalone stereo system that I can connect the front pre-outs of my Yamaha av receiver to access the power amp section. I have a monster of a power amp for the fronts and a musical fidelity pre-amp but it has no ht pass thorough and my power amp only has a single set of inputs.
    Nick
  2. Turlough
    Turlough
    Jan 13, 2004
    409
    Land of the Nimbys
    +48
    Linn Klimax Kontrol - bargain second hand atm but may be a bit OTT for your application.
    Look under "unity gain" to find other examples.
  3. stevos
    stevos
    May 16, 2004
    6,218
    +595
    Arcam and Cyrus pre's have it.
    Well they have a fixed level input, so not completely a pass through.
  4. lokyc
    lokyc
    Aug 28, 2013
    2,176
    83
    +429
    Its a feature found mostly in North American preamps.
    The best value is the Parasound P5. Emotiva does one as well. Then it gets a bit pricey.
    My Simaudio 350P will be up on sale tonight.
  5. sounddog
    sounddog
    Dec 11, 2002
    3,448
    107
    Leicestershire, UK
    +480
    Rotel have a couple. Also (iirc) Classe.
    The alternative would be to add a 2-way line level switch between the two pre-amps and the power amp.
  6. bass007
    bass007
    Apr 8, 2004
    1,514
    london
    +36
    Musical Fidelity M6 Pre & M8 Pre have the HT bypass feature.
  7. lokyc
    lokyc
    Aug 28, 2013
    2,176
    83
    +429
    They do indeed. Just not the M3 which I think is what the OP has.
    After the Parasound P5, I think the next one up in price point is the M6 pre. Big jump.
  8. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    Yep all Classe Delta series pre amps have it.
  9. sounddog
    sounddog
    Dec 11, 2002
    3,448
    107
    Leicestershire, UK
    +480
    Nick ... I hope you are still following this thread as you've not responded.
    You really need to tell us what kind of budget you have. It would also be worth listing the model number of the equipment you currently have.
  10. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    The other thing you may want to look into (if nothing with HT bypass fits your budget) is find a pre amp with a relative volume control and just set it to 0 with that input.
    I have been doing this for a while now having sold my Classe pre amp and I haven't deafened myself yet.... (famous last words...)
  11. Nickyrboy
    Nickyrboy
    Feb 25, 2005
    71
    11
    Bristol
    Hi all
    Thanks for the replies so far lots of food for thought. My current pre-amp is a musical fidelity from their Electra range so relatively low end (I think) I have a budget of absolute top £2000 but would prefer to be around £1500 or so. The power amp is a krell 400 driving some IMF pro monitors that I have made various crossover and high frequency drive unit changes to. It's a really great sounding setup and I want to retain that and not lose the quality in Stereo sound but use the krell in a home cinema setup to drive the fronts. I also have demon pma 2010ae which is an integrated with unity gain which the wife prefers as she only has to push a button on the denon to access unity gain whereas with the krell current setup it involves swapping interconnects etc. I know the denon has pre-outs so it could do it but it just doesn't sound as good as the musical fidelity setup so perhaps the m6 is the way to go. Thoughts?
    Nick
  12. sounddog
    sounddog
    Dec 11, 2002
    3,448
    107
    Leicestershire, UK
    +480
    I'm sure there are others ... but at that price range I could suggest...
    Rotel RC-1570 and RC1590.
    Cambridge Audio 851E
    Cyrus Pre
    and as you say the Musical Fidelity M6 Pre
    A slight oddball suggestion but a Naim NAC155XS and FlatCap XS
    Beyond that a lot of second hand options ... perhaps a Classe CP500, older Arcams, Linn.
  13. TomScrut
    TomScrut
    Jan 11, 2012
    2,669
    Scarborough, UK
    +438
    CP500s are good for that sort of money. I had one for sale till a few weeks ago. Very good pre amp. 2k would also maybe net you a Klimax Kontrol, probably not a current spec one though
  14. Timmy C
    Timmy C
    Oct 10, 2003
    5,647
    +573
    I know both the Arcam C30 and C31 will do it. I have owned both for that exact reason. Just had a quick look at the new C49 manual and it looks like it will too but I have no clue what it costs!
    C49 - Pre Amplifier - Arcam
