I'm currently running simple set up of Yamaha HS5's through a DOUK Audio Pre-Amp (Link below). I've just bought a second had pro-ject debut 3 to add to the set up, and the volume is very low even when everything turned to the max, which I'm assuming is due to the pre amp not having enough power to convert the sound enough.
www.doukaudio.com
Please can someone give me some advice on whether there's an easy fix for this, or whether I will need to invest in a more power pre amp/amp?
Connor
Douk Audio P1 HiFi Bluetooth 5.0 Vacuum Tube Preamp USB DAC APTX Preamplifier
P1 can be used as HiFi tube Preamp, USB DAC or headphone amp.With Bluetooth 5.0 (QCC3008) and PC-USB (CM6642),compatible with Windows/Mac/Linux system, match with most of home audio stereo system devices.Exquisite appearance with proper size.
Connor
