Practising headshots
newbie1
=adrian=
I think for black background shots there should be some sort of backlight to help to separate the subject from the background, hair light or kicker light. Unless that was what you had in mind.
Also remember that, especially for females, short lighting is more flattering (unless your subject is very skinny).
Overall a very good attempt :)
newbie1
Thanks Adrian, hopefully I get a chance to try again today :)
=adrian=
The first one is my favourite. The only thing that is missing (for me) is a bit of light from to back to separate the dark hair and the black background. But that is only a minor complaint. If that was your idea from the start and it does not matter what others think.
The one with white background is good one too. Peter-Hurley-like
The other 2 are not bad either. It is just I would be tempted to go with short lighiting in both of them and add a secondary light.
All of that is just a personal preference though.
sep8001
Great set and very good exposure on the face. Agree with a bit of back light on the ones with the black ground.
Please can you post what light setup you used.
newbie1
Lighting setup:
Black background - medium octagonal softbox above, reflector below and polystyrene panel to the side for extra reflection on one side.
White background - three strip softbox from the front and a couple of flashes behind - you can see them reflected in the catch-lights
snerkler
I think lighting is very good, nice and even and no horrible shadows. My only critique is that they seem a bit soft and focus seems a tad off ( the furthest eye is sharper than the nearest eye on 2 and 3. 1 just seems soft as neither eye is sharp, focus seems to be on the cheek)
newbie1
newbie1
I was using the hassy which has only center focus. Need more practice.
newbie1
Thanks, are all the lights speed lights or studio lights as well ?
The black setup was speedlite, the white was studio lights.
MartinH32
A couple of things if you don't mind me saying (I do this for a living). With a black background you really need a second light to provide separation of the subject from the background.
Lighting your subject from one side and shooting from the other (ie. shooting short lit) provides a more flattering result (it thins the face). Also try and get your key light (your main light a little higher). If you've not looked it up before google portrait lighting patterns and learn the difference between butterfly, rembranht, loop and split lighting. This will help turn your results into something quite special. Distance of your light to the subject will also play a major part in the overall look - the contrast and hardness of light varies depending on distance.
Pay attention also to the focal length you are shooting at. A longer focal length provides a more flattering result. Google foreshortening which will explain it.
Lastly, cropping heads isn't a problem. The way our mind works when viewing a photograph is to view shapes first, hence a round face. Cropping the circle helps you to concentrate on the subject. However, you need to take care where you crop!
Hope that helps
newbie1
Thanks for the detailed feedback, much appreciated :)
MartinH32
Just an example of cropping heads. It's only a small one but it helps to bring focus on to the couple. Had the grooms head been left in tact and space above it the shot wouldn't have worked as well KARLEY-1299.jpg
newbie1
Very cool :) thanks!
=adrian=
My rule for tight portraits / headshots is to have eyes above the center line. The top of the head is less important for me than the neck.
snerkler
Hope that helps
For the OP, I find this a good simple reference for portrait lighting
Ali Raza
add the hair light and follow the rule of 3rds...keep the subject to one side or the other...not in center..
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
Latest News
Hisense TVs get Disney+ on VIDAA smart OS
  • By Andy Bassett
  • Published
Astell&Kern launches entry level SR25 MKII portable music player
  • By Andy Bassett
  • Published
LG rumoured to release 97-inch OLED TV in 2022
  • By Andy Bassett
  • Published
What's new on Blu-ray (UK) for Halloween 2021
  • By Mark Costello
  • Published
AVForums Movies Podcast: 20th October 2021
  • By Phil Hinton
  • Published
