Practicalities, siting power for ceiling mounted PJ
Discussion in 'Projectors, Screens & Video Processors' started by zAndy1, Nov 5, 2003.
  1. zAndy1
    zAndy1
    Nov 26, 2002
    19,397
    2
    5
    163
    +6,514
    I was just wondering, if I have my projector ceiling mounted that presumably means having a socket in the ceiling joists somewhere. If that's the case assuming the fuse in the plug goes I presume I'd have to get to the power socket somehow (carpet up/floor up) to change it? Isn't that a bit of a pain?! Is my assumption correct (I can't see any other way to be honest)
    Andy
  2. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +216
    Run a long cable along the ceiling, down the wall and into a wall socket.
    That's what I'm planning on doing anyway. A bit of trunking painted the same colour as the ceiling/wall and it shouldn't be too noticable.
  3. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    snap..... you will probably be able to get away with some pretty ligthweight flex too so even easier to hide
    ad
  4. Woz!
    Woz!
    Oct 27, 2003
    107
    16
    Bracknell
    Whichever method used, it's an idea to try and take power from the same spur as the hi-fi it will be connected to, to aviod the problem of mains hum which can occur if you have a voltage differential accross two earths......
  5. mcaw
    mcaw
    Sep 1, 2003
    92
    I cut the mains plug off my power lead, drilled a small hole under the carpet in the room above, fed it through, replaced the plug, and plugged it into a wall socket there.
  6. WeirdFish
    WeirdFish
    Jun 28, 2003
    881
    Hadleigh, Essex
    +15
    With a big red sticker saying Do Not Remove!! :eek:
    I know I'd be half way through a movie and be plunged into darkness followed by the distant sound of a hoover :suicide:
    :D
  7. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    Does anyone know the length of the power cord?
    Im ceiling mounting 9ft away from a plug point!!!! I stupidly didnt fit a new plug point when I had the chance. Guess which cable is going to be visible!!!
