PPhilips SBC-RU940 Pronto 2MB???
Discussion in 'Home Cinema Control & Remote Controls' started by stephenc, Jul 24, 2002.
  1. stephenc
    stephenc
    Sep 26, 2000
    1,450
    116
    Dunfermline
    +518
    I've read through a few of the threads here and it seems that the Pronto get a lot of praise. I'm looking for a fairly inexpensive learning remote that will replace my 6 remotes.
    Is the SBC-RU940 Pronto 2MB the best place to start?
    And, does anyone know if it can learn the Pace DVTA DVB remote control?
    Finally, do I need anything else apart from the remote control itself. letsautomate.com has docking kits, basic starter kits and more on offer. All I want to be able to do is set the thing up, preferably by downloading them from remote central.
    Cheers,
    Stephen.
  2. Noman
    Noman
    Prepare for a learning period of 40 to 80 hours in front of the computer and the Pronto Edit software before you can think of creating a good setup for your gear that uses the abilities and that are easy to handle.
    Of course you can get it to work in a simple way in a couple of hours, but then you will be better of with a One4all.
  3. Doug
    Doug
    I agree,it's taking me a long while getting used to my 940,so many downloads available off remotecentral.com,it's all a bit mind-blowing at first!
    Be careful though, I think Pace use a different IR coding system to evryone else and the Pronto can't learn this..
