POWERSTRIP settings
Discussion in 'Desktop & Laptop Computers Forum' started by (GTV)Chris, Jun 25, 2002.
  1. (GTV)Chris
    (GTV)Chris
    Apr 30, 2002
    706
    Manchester
    +3
    Ok, I am confused...
    I have set my AE100 up using someones powerstrip settings.
    Then Someone posted different settings.
    What are the correct timings on powerstrip for the AE100???
    Cheers.
  2. Kramer
    Kramer
    OK, there seem to be several different "custom timings" in Powerstrip to achieve Wide 480 from the AE-100.
    The one I use was the one I mentioned, & I got this from here , over at AVS Forums.
    The one Hoglet posted no doubt works also, so both settings are correct.
    I haven't tried those other timings, will some day to see if there is any difference.
    Sorry for the confusion.
