Powerstrip Settings
Discussion in 'Desktop & Laptop Computers Forum' started by jameson_uk, Mar 14, 2005.
  1. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    I have a 4:3 Sony CRT TV and have just plugged my Radeon 9200SE into it using a VGA => RGB Scart cable.
    I setup powerstrip as per http://ryoandr.free.fr/english.html for 720x576 50hz (PAL)
    I get a picture and the colour and definition is great but the screen looks like it is shaking.
    What do I need to do to sort this out ??
  2. Rambles
    Rambles
    Jul 14, 2004
    8,473
    UK
    +1,352
    Try different refresh rates?
  3. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    I have tried changing the settings but nothing seems to make it any better (probably because I have very little idea what I am doing)
    After playing I am guessing that the front and back porchs are padding in the signal and together with the actual picture and sync make up the correct number of lines. Is the sync value actually important though or is it just to balance the porchs ??
    What sort of refresh rates should I be looking at. I presume for PAL it should be 25 as it is interlaced but what sort of range should I try ??
  4. Rambles
    Rambles
    Jul 14, 2004
    8,473
    UK
    +1,352
    :confused:
    Crikey, bit beyond my understanding here,
    But would guess at somewhere between 49hz and 85hz, have you checked the manual that comes with your display device to see what it supports?
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    With either NTSC or PAL any refresh rate that is a multiple of the basic framerate will do, ie. for PAL the usual for a CRT would be 75 to avoid flicker, while NTSC movies would be 72 (multiple of 24fps), NTSC video shot at 30fps is problematic since 60hz is below the flicker level and 90 can be somewhat high for some displays.
    So, your attempt at 50hz is correct but possibly your CRT doesn't like it that low, try 75.
  6. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    I am presuming that 75Hz would equate to 37.5 interlaced ??
    Also I am a bit worried as my TV is a few years old now (manual is (c) 1996) and I know it can take NTSC, so 60Hz should be ok but it is certainly not a 100Hz tv so is sticking a signal in @ 75Hz going to damage it ??
    The model is a Sony KV-29F1U but I have not been able to find out anything about it on the net and the manual doesn't say anything about frequency
  7. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Sorry, forgot about interlaced since all the time I've used an HTPC has been with digital displays being fed progressive.
    Not really sure to be honest what you need to set it for a CRT. :rolleyes:
    All I can suggest is trial and error. If you increase by, say, 5 hz at a time you'll not damage the CRT if you go slightly over the range it can support.
  8. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    I know that it looses sync @ about 27Hz but I think it also gives a picture @ 30Hz for NTSC.
    I will try 37.5Hz and see what happens :eek:
