Powerstrip settings for Panasonic TH-50PHW6
Discussion in 'Panasonic TVs Forum' started by loonatic, Jan 4, 2004.
  1. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    I have been playing about with Powerstrip for ages trying to get 1366x768 - preferable at 50, 60 and 75Hz - on my new 50" PWD6 but I'm not having much luck.
    Anyone got any ideas ?
    Stoomonster - what settings are you running on your 5 series, I guess they should be the same ?
    I should say that I have a Radeon 9700 video card and I'm using VGA - I gather that the DVI input only realy likes 60Hz.
    Cheers, Lee
  2. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    Have a bump on me, I should be ordering mine by Monday and I have exactly the same sort of questions, regarding what the VGA or RGBHV inputs will accept in resolution and refresh rates??
    See my thread here....
    Lee, can I ask how your getting along with your 50PWD6, great/good/bad??
    I can't wait to get mine, but at the same time I can't help being very nervous when it comes to spending 5k on a display.
    I'm going to be running mine with a Lumagen so I'm very interested in how I'll be able to fine tune the resolution/refresh rate to get the best out of it, how are you getting on with your powerstrip settings?
    Any hints or tips you want to share as a proud owner?
    Ryan :smashin:
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    My "media" PC (living room PC) has a Radeon 9700pro graphics card, runs WinXPpro, and Powerstrip.
    I am always confused about Powerstrip questions, it all seems very simple to me. :confused:
    I go to Advanced Features to create a custom resolution: enter 1366x768 for width and height and then set say 85Hz for vertical refresh rate, ignor everything else and add resolution, then go back to front screen and select 1366x768@85Hz.
    If the picture isn't centreed I either use size/position on horizontal/vertical or the picture position settings in Powerstrip; or a combination of the two.
    Am I missing something?
    StooMonster
