Powerstrip Resolutions.. Which One?
chuckalicious
Established Member
Joined
Sep 15, 2004
Messages
247
Reaction score
4
Points
62
Okay, I've been using Powerstrip with my vga-scart cable for a few weeks now using the 1024x576 or whatever it is resolution and it's pretty good.
However, on some forums I've noticed other people are using different resolutions, I think one is 720x something...
I also read in one place that the 1024x576 is the native widescreen resolution, but on another forum I read that the 720x something is the best one to use.
I couldn't find the PAL 50Hz 720 one, so does anyone have the settings, and is it worth changing it? I'm about to switch from a DVB-T tuner card to running Sky Digital either over composite or S-Video into a PVR 150 so I don't want to run at a higher resolution than the picture should run at.
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
