Powerstrip & matrox 450 dual head
Discussion in 'Desktop & Laptop Computers Forum' started by Threadkiller, Feb 9, 2003.
  1. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
    I curently run my LCD monitor off of port 1 and my panasonic PTLC75E off of the second port, Is there anyway I can apply powerstrip settings to my Projector? any settings I set affect my monitor, but I cant get them to apply to my PJ :( I've tried mailing entech several times but get no reply
  2. jbalat
    jbalat
    I actually used powerdesk to set up my Marvel. It can do everything powerstrip can do. Just check the manual for the correct modes for your projector. Use different resolutions than those for your monitor so that you know which to select.
  3. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
