Powerstrip and the Panny....help!
Discussion in 'Desktop & Laptop Computers Forum' started by MarTTy, Jul 12, 2002.
  1. MarTTy
    MarTTy
    Jun 10, 2002
    34
    I have recently installed Powerstrip and have put in the correct parameters according to the details on the Forum. But I still seem to have a distorted image. Do you have to select a new driver so the PC knows the Panny needs a WIDE image. I tried last night but couln't get the damn thing to work. Can someone enlighten me. I need it tonight as my missus wants to go looking at dishwashers.....and that's a no-no when I have a new toy to play with.
    Martin
  2. wolfe
    wolfe
    Make sure that the panny is set to wide480 in the PCPriority menu
    Also install a monitor driver for a Sony GDM W-900....
    It looks awesome when you sort it:D
  3. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    whats that do then ???
  4. wolfe
    wolfe
    It makes your HTPC think it is connected to a widescreen monitor....check Li-On posts at Avsforum...worked a treat for me....
