Powerstrip and PTAE100 help
Discussion in 'Desktop & Laptop Computers Forum' started by nwgarratt, May 17, 2005.
  1. nwgarratt
    nwgarratt
    May 5, 2002
    26,403
    +2,858
    I have had my PTAE100 working on my computer for a while. I just noticed that the text is not that clear in some parts. Some bits are a bit blurry. If I move the text to another part of the desktop it looks sharp again.
    Is there a timing setting in powerstrip I can adjust to clear text? It is set to 480W for DVD's or 800 x 600 for web surfing.
  2. Pack Dude
    Pack Dude
    Feb 6, 2002
    870
    Lost In Space
    +98
    Make sure keystone is set to zero. Also try the auto setup in the position menu.
  3. nwgarratt
    nwgarratt
    May 5, 2002
    26,403
    +2,858
    No keystone is used and done the auto setup already.
  4. Scotty
    Scotty
    Feb 12, 2002
    1,467
    Home Counties
    +412
    Sounds like Dot Clock or Clock Phase drift.
    Turn on your projector and ensure its receiving a signal from your pc, windows desk top is fine, leave it a good 15 minutes before using the auto setup this usually clears the problem.
    You can manually adjust the Dot Clock or Phase if the auto setup doesn't clear it completely
  5. nwgarratt
    nwgarratt
    May 5, 2002
    26,403
    +2,858
    Thanks for the replies. It did seem to be better the longer I had the projector it on but it was still there.
    I try the auto setup again later.
  6. nwgarratt
    nwgarratt
    May 5, 2002
    26,403
    +2,858
    I just had the projector on (just watched a bit of ST: First Contact with it :))
    The picture seem ok now except for a couple of bits of text with grey shadow.
    I couldn't find that dot clock/phase option in the PJ menu. I found it yesterday.
  7. Scotty
    Scotty
    Feb 12, 2002
    1,467
    Home Counties
    +412
    Its in the Position menu, same page as the Auto Setup, the headings are
    DOT CLK and CLK PHASE
  8. nwgarratt
    nwgarratt
    May 5, 2002
    26,403
    +2,858
    Ok, thanks.
  9. nwgarratt
    nwgarratt
    May 5, 2002
    26,403
    +2,858
    I have done the auto setup. The text looks normal again. :)
    The picture looks great. I am using wide480 mode at the moment. If I use 800 x 600 and do auto setup again. Will it mess wide480 up or have its owns settings?
