powerstrip 50 hz with domino30h
Discussion in 'Projectors, Screens & Video Processors' started by mrsnak19, Feb 6, 2005.
  1. mrsnak19
    mrsnak19
    hello, help thanks:
    j have a domino 30h with the htpc ati radeo9800 pro, but j dont'have a good setting for 50hz, in orizzontal geometry that number for front porch? - sync vich? - back porch? - in vertical perhaps I have found the just number is:
    front porch 1 - sync vich 3 - back porch 17.
    Thaks for help, hello.
    mrsnak19
  2. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    hi there, have you figured this out yet?
    I have the sim2 DMF and I can get it to work fine at 848*480 with a refresh of 60 hertz (just by using catalyst drivers). When I use the judder test though i loose the occasional frame.
    When using powerstrip it won't lock onto 50 hertz at that resolution (though it seems to at 800 * 600 for some reason). Perhaps powerstrip and reclock together is the solution?
    CaM
