Powerline adapters with Netgear switch
redcoupe
Shortly going to have a garage conversion done and would like to know if I can make use of powerline adapters to get network connectivity in the new room. I'll be wanting to use a Xbox, PS3 and possibly a future smart tv out there.
We use Virgin Media for broadband and all my kit is in the living room at the moment so I was wondering if I could make use of some powerline adapters to connect everything up in the new room?
Also, to provide more than one ethernet connection in the new room, would I be able to make use of an FS108 8 port Netgear switch I have?
I was looking at the multiple port powerline adapters but if I can make use of my switch then I suppose I could cut costs a bit and just buy single port models.
Many thanks for any help
mdbarber
yeah "should" all be ok can't state 100% for defo but have set similar configs up and they worked just fine
redcoupe
Thanks for your reply maddogb.
I think it might be a lot simpler, cheaper and reliable to just get the sparky to put in a network cable before the walls are done.
Kristian
You've covered it in your second post but I was going to say that if possible run a couple of Cat5e cables into the garage and put a switch on the end of one (the other is spare). Or run a bunch of cables back to the house and connect them into your switch/router there.
