Powerline adapters and SKY
Discussion in 'Networking & NAS' started by Ferkin Falco, Jan 5, 2012.
  1. Ferkin Falco
    Ferkin Falco
    May 13, 2007
    28
    4
    Apologies if this has been asked/answered previously but I'm planning to try and use a pair of Powerline adapters (one wireless) to improve the reach of my rubbish SKY router so I can get a better wifi signal in our bedroom.
    Anybody done this already or had any problems in trying to achieve it.
    This is a last resort as been told by several sources that you can't directly improve the reach of the SKY modem or swap it for a different make....or is that just a conspiracy theory?:rolleyes:
    Ferk
  2. maf1970
    maf1970
    May 2, 2006
    2,054
    Aberdeen
    +294
  3. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    ^ this. Or adding a second router to increase the blanket range of your wifi.
  4. maf1970
    maf1970
    May 2, 2006
    2,054
    Aberdeen
    +294
    You could add a second wireless router(If you have one spare) in the bedroom but you still need a physical connection to the SKY router to get Internet. Normal homeplugs would be fine for this.(But you would still need to buy them)
    IMHO what I suggested is the easiest way to achieve what you want.(There is a wide range of wireless homeplugs available so you can pick and choose. Just make sure they are at least 200Mb speed.)
  5. Ferkin Falco
    Ferkin Falco
    May 13, 2007
    28
    4
    Perfect!:thumbsup:
    Thanks for the prompt response all! Happy to go spend the money on Homeplug kit bit didn't want to do it and then discover it wouldn't work.
    .....now where's that debit card...or better still, the wifes! ;)
  6. Ferkin Falco
    Ferkin Falco
    May 13, 2007
    28
    4
    OK. Finally plumped for the D-Link wireless network starter kit but and got it all up n running, but, being a bit of a noob to all this wireless stuff I need it to run as part of my existing Sky Broadband network and at the moment it's running as a seperate network completely.
    Any clues?:lease:
  7. beerhunter
    beerhunter
    Nov 9, 2005
    6,335
    Hampshire
    +740
    Go to the Wireless settings of your new WiFi adapter and set the same SSID and encryption as the Sky router BUT on a channel that is at least two channles away from that of the Sky router.
