Powering on the Panny!
Discussion in 'Plasma TVs' started by JonathanCassar, Jan 10, 2005.
  1. JonathanCassar
    JonathanCassar
    Dec 30, 2004
    47
    I got myself a new 37" Viera and I'm very impressed.
    One slight niggle however is that I cant get the unit to power up on a control signal. I got used to pressing the SKY button and my old TV powering up from standby - can I emulate this on my new plasma?
    The GF wont appriciate a two stage switch on!!
    I thought of using a sky macro - but dont think this will work as you need to hold down the standby key to power on..
    Any suggestions greatfully received!!
    Jonathan
  2. JonathanCassar
    JonathanCassar
    Dec 30, 2004
    47
    the sound of silence is deafening!!
    Come on im sure someone has found a way of powering on a panny plasma from pressing the SKY button!!
  3. nic@highgroundd
    nic@highgroundd
    Jan 10, 2005
    182
    +3
    Attempted this myself - there is a toggle in the set-up to set which device should be dominant when switching on i.e. the TV or AV. You've tried this?
  4. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I just leave the skybox on permanently. I've had it since they first came out and it hasn't played up so far.
    Plus it feeds 5 other tv's through the house and one could be in use anyway.
  5. JonathanCassar
    JonathanCassar
    Dec 30, 2004
    47
    Thanks for replying Guys!
    the TV/AV option will select AV when you power the TV on - It doesnt however turn
    the TV on from standby when the control signal is sent from sky+
    I could leave sky on - I'd rather not though (with it being sky+) I like to power down my stuff at night.
    The panel does seem to go blank when I turn sky off - I'm not sure though if its a good idea to leave the Viera on?
