Powering off the TV - LE40R74BDX
Discussion in 'LCD & LED LCD TVs Forum' started by tsutton, May 5, 2007.
Tags:
  1. tsutton
    tsutton
    Apr 1, 2007
    137
    +4
    Maybe I'm being thick, but how do I power off the TV - LE40R74BDX - and not in stand by mode?
    I press the power button on the remote control, the TV goes into stand by. But when I press the power button on the TV, it just switches on and not powering off.
    How do I power off the TV apart from switching off at the mains (which I want to avoid as it's hidden away) or am I stuck with the stand by?
  2. suttons
    suttons
    Dec 31, 2006
    50
    11
    +4
    I have a n73 and as far as i know you cant turn it off. Not the best idea in the world but there you go. I just turn mine off at the wall at night.
  3. tsutton
    tsutton
    Apr 1, 2007
    137
    +4
    *bump*
    Anyone with R74 can confirm?
  4. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    You are probably used to hearing your old CRT tube TV power off and the red light go off. Well LCDs don't have a tube, so when you turn it to standby, this IS the off mode. The red light is to show its plugged in.
    Unplugging at the wall can erase settings after a while.
  5. tsutton
    tsutton
    Apr 1, 2007
    137
    +4
    Thanks for the reply.
    But with the standard CRT, I press the power button, the power is totally off and no stand by which means it doesnt use any electricity at all.
    With this TV, the red light is on, which means it's in standby mode and is using up electricity, right?
