Powering headunit outside of car
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by MickyBoy, Aug 2, 2006.
  1. MickyBoy
    MickyBoy
    Nov 15, 2001
    114
    londinium
    +4
    Hi all,
    I recently removed an old clarion headunit from my car and only realised afterwards (don't laugh) that i had left a bunch of CD's in the now redundant boot Clarion CD-changer :suicide: . The new headunit doesn't control the CD-changer.
    Have been in touch with Clarion and they said there is no manual eject and only option is to dismantle the CD-changer :( I'd prefer to leave it in-situ for when I sell the car, so is there a way to provide power temporarily to the old headunit and connect it to the CD-Changer (the connecting cable is still routed through the car into the passenger footwell so thats no problem) long enough to eject my CD's
    Ta,
    Mick
  2. Paulie-W
    Paulie-W
    Apr 13, 2006
    4,015
    +493
    You could try a battery charger. It should work (i think).
  3. GaryB
    GaryB
    Nov 12, 2002
    5,396
    St Albans
    +1,307
    Nooo. Don't use a battery charger, at least not until you've checked the output first. Off load you will find that most of them deliver a lot more than 12 Volts.
  4. Paulie-W
    Paulie-W
    Apr 13, 2006
    4,015
    +493
    Ok ok my bad :suicide:
    I did read elsewhere here about using a 21v low wattage lighting transformer. I bought on of these a few weeks back and it was only £9.
  5. AMc
    AMc
    Nov 20, 2000
    7,618
    Near Norwich
    +4,363
    Potentially dumb suggestion - can't you simply run some wire from the battery terminals to the power of the unit?
  6. GaryB
    GaryB
    Nov 12, 2002
    5,396
    St Albans
    +1,307
    Nothing dumb about it. That would do the job fine. The only thing I would say is to double check the polarity and then check it again before connecting up. It would be best to use an inline fuse, just in case.
