Answered Powering Dashcam in BMW
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by G a f f e r, Jan 15, 2017.
  1. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,041
    U.K.
    +666
    Bought new car - 2015 BMW 330d xDrive - haven't had it delivered yet, but is it possible to power a dashcam from the 12v socket UNDER the glovebox (the one in the upper surface of the passenger footwell), or is it not powered for that (i.e. cause any issues)?
  2. G a f f e r
    G a f f e r
    Dec 31, 2003
    3,041
    U.K.
    +666
    Well, the car arrived and so did the dashcam (Viofo A119 - 1440p30 wide angle recording on a Lexar MLC 32Gb microSd (3.5ish hrs recording)). Placed it to left of rear view and routed wire along headliner, down and across A-pillar, under glovebox and into accessory socket.
    Turns on when car unlocked and door opened, turns off a few minutes *** after closing door/locking/alarming it :thumbsup:.
    EDIT: Piccies added:
    Mounted snugly behind the rear view mirror
    [​IMG]
    Routed up in headliner, down A pillar and behind rubber trim on side of dash
    [​IMG]
    Then placed into accessory socket for power
    [​IMG]
    Looks inconspicuous enough...
    [​IMG]
    *** EDIT 2: Just timed it using the dashcam itself.....the 12V socket goes out exactly 3min after the doors are locked in the F30 (which isn't an appreciable battery drain).
  3. True Romance
    True Romance
    Feb 7, 2005
    6,962
    Wolverhampton
    +3,028
    Installed mine pretty much the same, brilliant idea by BMW putting a 12v socket under the footwell.
