Powered speakers with airport express - which?
freddyuk
I believe i can use powered speakers instead of an amp to play I Tunes via the express. What speakers should i go for and will they give decent quality sound or just stick with standard amp and speaker setp?
lazymatt
Depends on how much you want to pay.
The AE Aego T's are a good 2.1 system for less than £100.
The Audiengine A5's are very nice at about £230 and are designed to work with the Airport Express, and have a power port on the back (although it's a European plug socket, so you need a travel adapter)
