PowerDVD v5 & Sleep Mode.....
cosmic023
Hi All,
An interesting question for you all.............
When watching a DVD movie on my HTPC, how do i activate say the screen saver once the credits have finished ?? I think i could use repeat in PDVD5 to replay a movie ?? Is this Correct ??
The reason i ask, is because if i nod off during a movie......and wake up several hours later........i'm scared at the thought that a static DVD menu image has been burnt into the face of the CRT tubes in my Barco 801s CRT PJ.
One option is to use DVD shrink and play it off the HD, i know i can then use the repeat function.
Any clues ?? I'm sure there must be a method to avoid this ??
Cosmic023
cosmic023
Anyone ?? Is there anyway of activating the screen saver ?? or Could i use Girder to activate the screensaver ??
KraGorn
I can't believe burn-in would be a problem after only a few hours to be honest, I think you're perhaps worrying unecesarily though I have no experience of CRT displays except for TVs and if a TV burnt-in after only a few hours I'd be pretty annoyed.
I can't see a way for PDVD to kick off the saver. TheaterTek has a screen-saver function, maybe if you're really concerned you could look at that.
As for using an external controlling program, I can't see how something like Girder would be able to detect the movie has finished playing .. best you could do would be to kick off a script running a timer just before you fire-up PDVD, the script might then be able to do something, it'd need some research I think.
cosmic023
Cheers KraGorn,
I'll look into that software, as everybody raves about it. Is it correct there is only a full version available, and no demo to try ??
What's the URL ??
Cosmic023
Samsung S95B QD OLED Review - A Quantum Leap for OLED!
