PowerDVD and screen capture
Discussion in 'Desktop & Laptop Computers Forum' started by Rigid, Apr 30, 2002.
  1. Rigid
    Rigid
    Does anyone run PowerDVD (V4.0) as supplied with a Dell PC? I've given up trying (OK, this is one last shot!) to find the 'Capture' tab which will enable me to set up my options for screen grabbing, on the basis that Dell must provide a cut-down version of the application. Please, please prove me wrong!
  2. Guest
    no idea on the cut down version, but it's plain as day on the config menu on the full version. I love that capture facility, it makes the best wallpaper.
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,769
    7
    2
    167
    Birmingham, UK
    +10,673
    Capture doesn't work if you have hardware acceleration enabled. Try disabling it and the option should become available.
  4. Rigid
    Rigid
    Interesting! I haven't manually enabled hardware acceleration (not that I remember, anyway), but I did install and run DVDGenie - might that have enabled it? Isn't hardware acceleration generally a good thing, though? Screen capture is a fun-feature, but I'm not sure I'd want it at the expense of picture quality.
  5. Rigid
    Rigid
    Switched off hardware acceleration (via checkbox) to no avail. I guess that can only mean one thing: castrated OEM version.
