PowerDVD 5 v Theatertek 1.5
Discussion in 'Desktop & Laptop Computers Forum' started by Canary_Jules, Sep 23, 2003.
  1. Canary_Jules
    Canary_Jules
    Jan 25, 2003
    3,366
    2
    Leicester, UK
    +877
    So how do PowerDVD 5 and Theatertek 1.5 shape up? I currently use MSIDVD which came with my DVD Rom but which is actually PowerDVD 4, I believe. I might be interested in upgrading to one or the other if it is worth it. But is it? That's the question. Has PowerDVD 5 caught up with Theatertek?
    Jules:confused:
  2. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    IMO Theater Tek still gives a marginally better picture than Power DVD5 although that may be purely down to personal taste.
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,149
    UK.
    +2,670
    I can't see a lot of difference between PDVD 4 and 5 picture quality wise, but 5 has a non linear stretch mode for 4:3 stuff like widescreen tvs. It also has an active image adjuster that makes everything seem brighter and more colourful. Doesn't look too hot on a projected image in my opinion.
    HTH
    Gary.
  4. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    Yeah, I'm not sure what to make of the CLwhatever brighness enhancer in Power DVD 5, it seems to overly saturate the colours, increase contrast too much, all leading to images losing their more cinematic feel.
    The jury is still out, perhaps I just need to tweak it a bit more...
  5. GRees
    GRees
    I know you asked about PowerDVD 5 and Theatertek 1.5 but have you considered WinDVD 5? I have just spent a week comparing Theatertek and WinDVD 5 and IMHO WinDVD5 just about beats Theatertek on my projector - providing you set the colour settings to "custom" and not the pre-sets. I also seemed to get smoother panning with WinDVD 5.
    Added to that the built in support for Dolby Digital EX and DTS ES ( something sorely lacking from Theatertek IMHO ) -as well as SP/DIF output there is no contest.
    I have only tried PowerDVD XP and I took it off after about 30 minutes - I thought the picture was awful - so I can't comment about PowerDVD 5.
    Just my pennies worth - for what it's worth :)
  6. slyborg
    slyborg
    Jun 16, 2003
    153
    +4
    If TT doesn't support ES/EX then I'm correct in assuming you will only get DD or DTS 5.1 out of your soundcard when playing such DVDs?
    Surely there must be a TT update in the works?
    Si
  7. Canary_Jules
    Canary_Jules
    Jan 25, 2003
    3,366
    2
    Leicester, UK
    +877
    I'm a little confused on the sound issue so please 'scuse me for asking such a noob question. But if I use spdif out to my AV amp which of the three packages mentioned (WinDVD, PowerDVD and TT) will permit me to reproduce DTS sound? Audio quality is as important to me as video quality and there is no doubt that DTS is tops as far as sound formats are concerned. I have just tried WinDVD 5 and my initial reaction is that the picture quality is better than in PowerDVD 4, which at times seems over saturated and lacking in definition.
    Jules
  8. tbrar
    tbrar
    May 31, 2003
    609
    16
    I have Power DVD5 & TT 1.5. I use SPDIF to may amp, both of which output DTS if on source and selected (if thats what you mean)
    To me TT gives a better picture (ever so slightly) also its aspect ratio/picture size adjustments is a fantastic feature. Consequently TT has the edge IMO.
    Also, I am sure I am able output EX/ES with TT, I will check tonight !! :D
  9. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    PMJI :) ... I'm looking at TT and read the manual about the AR editor, but I'm bemused as to WHY it's a great feature; certainly TT think it's great it has the largest description of any feature in the package.
    Just where do you find yourself using it? I'm a n00b to HT I know, but setting a custom AR seems a solution looking for a problem. :confused:
  10. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,149
    UK.
    +2,670
    If it's the feature I think it is, then it's possibly for people with anamorphic lenses and want the extra stretch for 2.35:1 movies.
    Gary.
  11. Canary_Jules
    Canary_Jules
    Jan 25, 2003
    3,366
    2
    Leicester, UK
    +877
    Be sure to tell us the results tbrar! I'm interested to know the outcome.
    Jules
  12. GRees
    GRees
    AFAIK you will not even get DD or DTS 5.1 out of TT if you are using a soundcard with active speakers or power amp connected to it. The only sound output you will get is Pro Logic as TT only supports DD/DTS via your S/PDIF to an external AV amp/Processor. Having said that, apparently you can get it to work with an Audugy 2 S/PDIF input if you mess around a bit, something I tried with my Audigy 2 ZS but gave up with after a while because of serious lip sync problems. Maybe someone cleverer than me could have got it working but given that WinDVD5 worked perfectly I really couldn't be bothered.
    WinDVD 5 has built in software decoders for DD EX/DTS 5.1 ES., so will work fine with any 7.1 soundcard.
    As far as Aspect Ratio is concerned, I personally don't need it as my PJ runs at 1024 x 768 so I just leave my PC set to its' standard resolution. However, if you've got a PJ with "non-standard" resolution I could see the appeal ot that feature with TT.
    I know ( read "hope" ) WinDVD will support anamorphic lenses - just turn "maintain aspect ratio" off - as its' something I'm currently looking at getting. I'd be interested in hearing from anyone who has experience with them.
    Gary
  13. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Since I'm using pstrip for my Panny 300 then is the AR feature of TT redundant then?
  14. tbrar
    tbrar
    May 31, 2003
    609
    16
    Firstly Im a Noob to HTPC, chose a HTPC to act as Video processor primarily, bonus that sound was as good as my previous Arcam DVD88+.
    The reason I like this feature is due to the different ways that DVD's are mastered, in that a 1:78:1 ratio movie may actually be a slightly different size depending on film.
    In other words if like me youre outputting 1024 x 768 (dot for dot to panel) you may get small black bars at the edge of the screen, that on another 1:78:1 ratio movie would not be there. With the AR control you can adjust as you watch, in real time, so that the picture fills the screen.
    To some I imagine this is not a great feature. To me on my panel I really like it.
    Also I am using Power Strip in conjunction with TT. This allows me to fine tune settings to my panel, ie refresh rates, porch settings etc. This then produces the best results for my set up (well was set up for me by Rob Screene)
    Just tested with Blade II, definatley got DTS-ES. Can you not hear it ?????:eek:
  15. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    With you, I've seen that once or twice and now you describe it I can understand the use of the AR feature ... I guess it also allows one to sacrifice a percentage of the picture watching a 2.35:1 in 16:9 mode by expanding vertically to eliminate some of the anamorphic black banding ... I do that sometimes using PowerDVD's Pan&Scan settings but the TT mechanism provides for fine tuning.
    Thanks for the explanation. :)
  16. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    Land of the Living, Essex
    +35
    you could just use zoom player which has all sorts of custom AR, res and zoom. It will work with any decoders you have installed.
  17. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,149
    UK.
    +2,670
    I see - it's like the feature Zoomplayer has where you can use the mouse wheel (or whatever you have it configured to) to make the image larger (or smaller).
    Almost like an incremental zoom function, and very useful for losing the ragged edges of some DVDs. You don't see them on TVs because TVs have something like 10% overscan.
    Gary.
