Power surge unit with battery backup for my projector ?
choccy
Having just had a power cut which turned my ax200 off and then the power came alsmot instantly back on so the fans cooled the lamp. So hopefully it is ok, but it made me think - do people think it is worth while to use a battery backup unit incase of power failure ?
How do they work ? Is that when there is a power cut they automatical stop the unit from switching off or is there a loss of power even for a second ?
Lastly, any recommendations ?
andyman2
Choccy
I had a similar experience a month or so ago. The power failed then came back on after a couple of seconds. I quickly powered the projector back on hoping to use the fan to cool the bulb, however to make matters worse the power then failed again.
I found this on ebuyer for £20
Plexus MV 650VA UPS With AVR - Ebuyer
its only 650 Watts but it will be enough to allow me to shut the projector down in an orderly manner. There are a series of these at different power specs depending on your need.
