"Power surge on hub port" when resuming from S3 standby
Discussion in 'Microsoft Windows' started by mark.carline, Nov 1, 2005.
  1. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    Does anyone else get this message in the taskbar when using the remote control to resume from S3 standby ?
  2. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
  3. OneEleven
    OneEleven
    It looks like you have too many devices plugged into your USB port.
    If you are using a hub, replacing this with a powered hub should solve the problem as power is provided externally rather than being drawn from the onboard USB port whihc is only supposed to provide a current of 500mA
  4. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    Nice try - The *ONLY* USB device I have is the generic IR receiver that came with my Microsoft MCE remote.
  5. OneEleven
    OneEleven
    :eek:
    That doesn't sound right - there's NFW the ME remote should be drawing that much current - that's 1/2 an Amp
    Does it do the same when plugged into other USB sockets? Do you get teh same message if the MCE receiver is unplugged and something else is plugged into that socket?
  6. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
    Do you get the same error message if you unplug the receiver and resume from S3?
  7. mark.carline
    mark.carline
    Jan 15, 2004
    2,132
    Chester, Cheshire
    +121
    Yep. Just tried it now with *NO* USB devices connected.
  8. Skunkpipe
    Skunkpipe
    Sounds like theres a short somewhere
  9. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
